Transmission problems
DallasM
Oct 26, 2021
Battle Creek, Michigan
A couple months back I changed my clutch, flywheel, and pressure plate, made sure I did everything correctly when installing. I adjusted the clutch, bled, and made sure everything was going correctly, but I'm very confused on what's going on now, the car refuses to go into gear and I have no idea why.
I've been trying to fix this for months now and have not solved the problem, I'm thinking about taking it to a shop but before I spend hundreds of dollars for somebody to fix it I want to hear your opinions.
Let me know if there's any other things I have to do, and bear with me this is my first time ever changing a clutch on a car.
Did you actually bleed the clutch hydraulics correctly?
If the answer is "Yes. I had someone pump the pedal, hold it down, then I opened the bleed screw on the slave cylinder and closed it <rinse/repeat>" then you didn't.
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
