dugan33
Supporting VIP
- 397
- 9
- Jun 11, 2011
Madison,
Wisconsin
Today I installed a Fuel Lab fuel pressure regulator, EGR block off, PTE 880 injectors, spark plugs, and ECMLink v3. The car idles but runs rich and bogs wayyyy down when getting on throttle. I don't have a clue what I'm doing with this ECMLink software.
So far I have changed global fuel settings and dead time to match the general values for PTE 880 on the website. I also adjusted the idle and rpm stuff but nothing crazy. I can't get this car in running condition after the install of these parts. I know its running rich still cause i pulled plugs, and the FPR is at 45. I'm getting a TPS error and my O2 is deadline at .06v when I unplugged it it was at .04v. but that might just be because I'm not able to rev it up enough to activate closed loop or whatever.
I pretty over my head here could really use some help thanks.
Make absolutely certain the ecu harness is completely plugged in. If it is, check the pin 23 wire...
