snakeyes711
- 645
- 0
- Feb 5, 2009
W-S,
North Carolina
So, after buying this basket case its coming together nice. So heres what I have done so far.
New transmission
Changed fluid in tranny, case, and rear diff.
new Transfer case
St. 1 exedy clutch
both front drive shafts
attached rear drive shaft, and got it bolted in.
Timing belt kit/new pulleys, and water pump
I did the basic stuff too, cleaned the IC, cut the back panel out. removed plug in BCS rest.
reset WOT, adjusted clutch travel. fixed boost leaks.
Is there anything I have forgotten to do you can think of tell me. Oh, I need to check base timing. It should be +5 at Idle?
I've basically done all the preventative maint. that was neglected when I bought the car.
I was going to get a 190, and a small 16g, and have it tuned but what else should I do that needs done first?
oh, I did a 2g exhaust manifold with new gaskets today the old manifold has about a half dozen cracks in it one almost wrapped all the way around between #2, and #3 on the right side of the turbo
I been shopping for a boost gauge for it. I can't seem to find a good two gauge combo. I was going to get boos t,and oil pressure.
New transmission
new Transfer case
St. 1 exedy clutch
, i said you should get a tuning program i.e. dsmlink, ok I should have said e.g. my bad, but then you go on and tell him the same thing, to get a logger and even said it yourself as an option get the link, that said and you obviously now your stuff can you put me straight on this as im now having trouble on understanding how you can put injectors that have a longer pulse width in to a car and not dial them in to the ecu, im not saying you cant but with what ive read it just dose not make sense.
