snakeyes711
- 645
- 0
- Feb 5, 2009
W-S,
North Carolina
So, after buying this basket case its coming together nice. So heres what I have done so far.
New transmission
Changed fluid in tranny, case, and rear diff.
new Transfer case
St. 1 exedy clutch
both front drive shafts
attached rear drive shaft, and got it bolted in.
Timing belt kit/new pulleys, and water pump
I did the basic stuff too, cleaned the IC, cut the back panel out. removed plug in BCS rest.
reset WOT, adjusted clutch travel. fixed boost leaks.
Is there anything I have forgotten to do you can think of tell me. Oh, I need to check base timing. It should be +5 at Idle?
I've basically done all the preventative maint. that was neglected when I bought the car.
I was going to get a 190, and a small 16g, and have it tuned but what else should I do that needs done first?
oh, I did a 2g exhaust manifold with new gaskets today the old manifold has about a half dozen cracks in it one almost wrapped all the way around between #2, and #3 on the right side of the turbo
I been shopping for a boost gauge for it. I can't seem to find a good two gauge combo. I was going to get boos t,and oil pressure.
New transmission
new Transfer case
St. 1 exedy clutch
I replaced the harmonic balancer today, and fired her up. After seeing it wobbling, today its straight as an arrow.
