Do you think this is solid or hollow tubing?
Ludachris
Founder & Zookeeper
8,878
4,725
Nov 12, 2001
Newcastle, California
Just wondering what kind of tubing that would be. It looks like rectangular aluminum hollow tubing to me. Where would you find that?
Chris, I'm 99.9% sure that's hollow. I couldn't imagine that they would use solid stock for a piece like that.
I pulled the fenders off my 1G a while back to see if a set of those could be made for it. There doesn't seem to be any good place to anchor it to. Not to mention that the 1G's are much stronger looking in that area compared to the EVOs.
This is probably the dimension that they used: Order Aluminum 6063 Rectangle Tube in Small Quantities at OnlineMetals.com
What's its purpose?
It stiffens the chassis and improves handling. The two articles I read about this mod on an Evo were very glowing. I don't know that it will help the DSM as much as the Evo, which is strange since the Evo chassis is supposed to be stiffer than the DSM, but it still has the potential to improve handling - even if it's just a little.
Agree. Looks like steel square stock that is painted silver. Aluminum welds have a certain look to them.
I pulled the fenders off my 1G a while back to see if a set of those could be made for it. There doesn't seem to be any good place to anchor it to. Not to mention that the 1G's are much stronger looking in that area compared to the EVOs.[/url]
Dang, 2g's are the same way, no good place to anchor. You would probably have to weld a tab to the chassis with a stud sticking out as an anchor spot (or something like that), then the brace could be a bolt on.
Here's one a guy fabbed for his Evo with round tubing.
Feedback requested: Fender brace design - evolutionm.net
There's always a way to make a chassis more rigid. You just need to think triangulation triangulation triangulation. Read and be inspired: Opera Performance Honda S2000 - Sport Compact Car Magazine (the third page is where the real magic is).
Looks like you could do something with the hole where the wire loom attaches... though it might require reinforcing it somehow... or hell, just drill a hole a few inches before that hole and use a nut/bolt to secure it for those who don't have the means to do any welding.
Anyone have a pic of this area on a 1G with the fender off the car?
Not that I don't believe you Paul. I'm just curious.
Do you still need the picture? I see the 2g there but if you need the 1g picture still mine is sitting at home in the garage with no front end body parts.
Alright, give me 6 hours LOL. I am just at work but when I get home I will snag a quick picture and post it up.
I'll have to take a closer look at it again, but I'm pretty sure you can't pass a bolt through that lip because it's not really a "lip", there's more body behind there. Now you really have me wanting to fab these up and see if they really do anything. Can I borrow your TIG :sneaky:
Come by the house - I'll let you use it. :p
I think just welding them up would be the easiest solution - or maybe welding a bung to the sheet metal. It's possible. I just don't know what the results would be, but it seems worth the effort in trying it.
I don't know that it would really be worth it on a 2g due to the suspension design (just like a strut tower bar isn't). A brace like that doesn't look like it would keep the area where the control arms bolt up in place any more than it already is.
Here are the photo's. Dont mind the one random small hole in the pictures, it appears to have been drilled in by the previous owner.
Looks like hollow steel. I have tubing EXACTLY like that at work, with the end flanges and everything.
Also, TIG looks like butter, and looks like it's REALLY smooth.
Mig is more rough.
Looks like steel that's been migged and painted.
