Resolved Dimmer stopped working after 10Amp fuse blown
sacrileger
303
48
Jun 26, 2016
Orillia, ON, Canada
I was replacing the stock stereo/tape deck with a better set up and forgot there is always one live wire to feed the clock and blew the 10Amp "room", NOT the "radio", fuse. No interior lights worked after that. The interior lights started working again after I replaced the fuse. Also, I did not re-connect the black/yellow car stereo dimmer wire - just taped it over.
After I put everything back together, I realized my dimmer switch no longer works - the dash lights are on full time. All else appears to work... at least I have not noticed any other problems yet.
1) have I blown the dimmer switch along with the 10Amp fuse with my antics?
2) does the stereo dimmer wire need to be connected to close the circuit and for the dimmer switch to work?
3) if the hot wire brushed against the black/yellow car stereo dimmer wire and blown the fuse, did it take the dimmer switch out with it as well?
There are many dozen threads dealing with dimmer switch problems, mostly 2G, on here. None appears to apply to the above scenario.
Where do I look first to find the problem?
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
