2g dimmer switch easiest fix without taking entire dash off
langelg6
52
13
Nov 4, 2019
Hammond, Indiana
hello my 95 eagle talons dash light are out but my tail lights work fine, so I have a replacement dimmer switch for a 2g, but I really ain't tryna take the whole dash off just for that... I will if I have to but im turning to the community to see if there is an easier way xD... I have heard of grounding the black/yellow wire to dimmer switch to the chasis, is there an easy sway to cut it under the dash and wire an extra piece of wire to the body.
Just get up inside the dash with some screwdrivers and a light. Unscrew it, then unplug it. I say unplug 2nd so if it slips when you remove the last screw, it won't drop down in your face. It's a bit of a pain, but simple enough to do this way.
