difference between automatic and 5 speed block?
jakk220
1,320
320
Nov 13, 2010
Akron, Ohio
I just bought a new block since mine blew up and my mechanic is assembling everything for me right now. However, he did say that the block was from an automatic eclipse. So far the only difference he noticed is that the driver side of the car it has the 2 piece axle with the carrier bearing that bolts up to the block in 2 spots and the auto block only has 1. Will this be suffice enough so that nothing bad will happen? Also will there be any other problems since it is an auto block?
Awesome. Thanks for the info. The flex plate was a pain to get off but other than that its going good so far. Just that theres only one bolt holding that bracket on instead of two. You thi?nk it will be fine
