daren_p
DSM Wiseman
- 4,605
- 98
- Nov 22, 2004
Newmarket,
ON, Canada
Kelton.. think of it this way, yes the engine will make 500 hp at XXXX RPM.... Cool! GREAT!!
But how often will the engine see that when it is a DD/ street driven, yes it is nice to have that amount of power on tap when you go to pass someone.
But out of 1000 miles on the engine, how many of them are at full load? I would guess with weekend warrior car, say 5-10 of hard abusive miles a couple times of month.
So the guy JAM talked about having 80k miles on his engine, may have about 800 hard miles on it...
as big as you are into it, how many hard miles and dyno runs have you put on your car in the past 5000 miles?
With this being the case, you have a 500hp engine doing the work of a 200hp engine, it will have a long life as long as proper mantiance is kept on it, that gose for the any engine tho.
Another thing to add to all that good info, it also depends what "type" of motor you have built. You ask them to build a loose race motor, guess what, you'll get a motor that makes great power but will require a rebuild much sooner. Ask your machinest to keep to OEM spec's & guess what, you have a motor that should last the same as an OEM motor
