rings for wiseco pistons
Well that would depend of the ring package on your Weisco pistons. You would need to compare the stock rings diameter, width, and height with with that required for your Weisco pistons.
You can however order a set of Weisco rings, if all else fails. They are most lokely more money, but Perfect Circle or Hastings rings will most likely set you back a C-note.
Like said above stock rings wont fit wieseco pistons.
Only wisecos' will fit wisecos without hastle but I think Total seal inc is the only other company that makes rings that will fit.
