- Thread starter
- #26
WES_393
DSM Wiseman
- 3,814
- 100
- Jun 6, 2011
Colo Spgs,
Colorado
Thanks for that bit of info Justin, I hoped you would stop by eventually.
I have verified that at my current oil feed line I have 90-95psi on a 30* cold start, 70-90psi while moving depending on speed/RPM/temperature (including WOT), and ~20psi at idle fully warmed up. If I touch the gas pedal at all at any time, the pressure shoots right up to 50-60psi. So I have the minimum requirements down, it's of course over feeding that I'm concerned with. The black filter/restrictor drilled out to a 7/64" should still be sufficient to keep me from blowing out seals, correct?
And thanks to the turbo being "broken", it cost me about the same as a full tank of gas in my Talon.
It would much cheaper and leave room for growth. From my research, an OBX manifold, Tial 38mm, and BEP T3 housing would land somewhere around $700 while PR mani, PR waste gate housing, and BEP bolt-on would be upwards of $900. So I'll have to ponder that for a little. But talk about indecisive, I went from bolt-on HX35 to T3 HX40.
It's not like I could complain if I made more power, easier, and for less money. So I guess I should edit my goals to "450-500hp, but more would be just fine".
