Talyn
- 443
- 19
- Jun 10, 2012
Pittsburgh,
Pennsylvania
Started with a substantial oil leak, that I couldn't find, then discovered coolant in the oil after putting dye in it and driving the car home, and am now pulling the cylinder head, it appears to have an MLS gasket on it, which makes me fear that I may have a warped/cracked head and or block....
Is it common for these to warp/crack heads or blocks?
Also any tips on cylinder head removal would be helpful, I know what I am doing, but I do not know these cars, looks like the easiest way is to pull it off with the exhaust manifold still on it and detach Ex manifold from the turbo, also looks like unbolting the Tstat housing is easier than detaching all its lines and such.
Then in the back it looks like I have to remove the coilpack, injector rail, and then the intake manifold?
