2G Coolant in oil
Dakota Biddinger
139
Aug 5, 2017
Juneau, Alaska
So I've been working on my car for a while now, and the first time it ever started the coolant mixed with the oil, so I pressure tested the cylinders and had low numbers so I changed the head gasket. Fast forward a bit and it's at the shop, they're almost done and they say that the coolant mixed with the oil again and that it's most likely a warped head. I take the head off, get it resurfaced and pressure tested, and put back on and everything hooked back up. Now today I go to the shop and go to start it up to pull it into the shop and we see that the coolant mixed with the oil again. Any ideas ? Debating whether I should pursue the problem and fix it or just sell the car. It's a 95 talon tsi with a 94 engine in it. 7 bolt. And yes I got new head bolts each time I took the head off and torqued them correctly
Its highly unlikely but what about a cracked CHRA
What block is in the car, and what head is on the block
You posted this exact thread six months ago
It's not rocket science here
Post up a picture of both the block with the head removed and a picture of the cylinder heads mating surface. Or are you still getting screwed by the same mechanic who for all you know isn't even doing any repair work
My thoughts exactly, considering how much has been spent already!
He has no idea. He just wants to keep asking questions with no intention to find the answer on his own
http://www.dsmtuners.com/threads/coolant-in-oil.515920/page-2#post-153678175
Idk about you but im only 18 and I dont have my own garage or tons of money to spend on 3 eclipses like you. Also, I have the only dsm guys in town helping me who know all there is to know about them. Not everybody is as experienced as you when it comes to cars, so you dont gotta act like in stupid or something just because I know less than you. I live somewhere that has one shop that works on cars older than 2005, and that's the one my car is at. The owner held the land speed record in the 60s or something for the quarter mile in a car he built, so in assuming he knows what he's talking about. Honestly im just gonna scrap the car and forget about this page since I get talked down to by you each time I post about something
you've been a member since 2002, so you're obviously a lot older and more experienced than me. Oh and im guessing you have a job? And can
Im just sick of seeing you comment on every post of mine half helping and half being a dick because I dont know everything there is to know about these cars
It's not hard buddy. It seems like I'm giving you a hard time, it's because we've explained everything to you 3 times.
So the only answer we haven't given you is that the block is cracked or the turbo is bad or hooked up wrong
There's not many places you can leak coolant from, into the oil.
Seriously, get a cooling system pressure tester and pressurize the cooling system. Drop the oil pan and watch to see where it's leaking from
Boom
You keep saying the mechanic did this, mechanic did that, but this is first year mechanic stuff
Pressurize the system with the oil pan off, and valve cover offf and find the leak
age means nothing i put my first engine in a car at 16. take a deep breath n look at what other are saying. personally if i spen 4000 and still dont have a running car i would scrap the mechanic not the car.
Some of the diagnostic tools you need to test stuff you can rent for free. If you're on a budget scrap the mechanic. If you truly have no skills....well this may be a lot harder.
Hmm, I'm curious as to how this mechanic can't figure the problem out? There's only so many times you can replace a head gasket thinking that will fix the problem. Either the car has a bad headgasket, the oil cooler sandwich is cracked, the turbo center housing is cracked or the block is cracked. I can't think of anything else that would mix oil and coolant.
