jed344
Supporting VIP
- 1,517
- 563
- Jan 10, 2008
Waterville,
Iowa
I am a little stumped right now. I have built a few coil on plug set ups with 300m coils over the years and use one i built right now on my car.
Other then resistance is there a way to test 300m coils for being bad?
A friend of mine we decided to swap to coil on plug as even with his ARC-2 box we had hit a wall with spark blow out. He got a used set up and we found was wired wrong for his car so it was rewired and still acted as if it had bad coils. I tested resistance and it showed to be to high. He then got another used Spark Tech COP that was wired right to start and did the same thing. I tested resistances on each coil and at the triangle plug and confirmed it matched my resistance and wired correctly. We grabbed another Spark Tech COP from a running car wired the same and same resistance and his car fired right up.
Something is clearly wrong with this coil on plug but can the coils be bad and still test good on resistance?
