2G Coil on plug set up
jmt2028
57
57
Apr 13, 2022
Memphis, Tennessee
My power transistor recently failed, or at least I think that is what failed based on the symptoms. Driving home one day and all of the sudden I lose what feels like two cylinders at the same time. I pulled over and shut the car off and let it sit for a minute while I run ecmlink on the car to see what it tells me. Start the car back up and idles fine on start up but as soon as I put into gear and put the car under load I get a random misfire again and what feels like the loss of two cylinders at the same time which leads me to believe the 30 year old power transistor is going bad. I am now in the market for a coil on plug set up to get rid of the 30 year aging coil pack system. Car is an early gen 1995 Eagle Talon tsi.
I am currently looking at purchasing the antilag racing coil on plug set up but they are currently delayed on their shipping due to waiting on parts from one of their vendors.
I have found a used antilag racing set up fior a decent price which claims to have brand new denso coils but the problem or at least the difference I see on the item posted for sale is that it appears to only have one deutsch connector plug, whether it is a 4 wire or a 5 wire I am not sure but I noticed on the photos on antilag racing website for their current set up is that it utilizes two deutsch connector plugs for replacement of the power transistor wiring and the coil pack wiring a 2 pin deutsch connector and a 3 pin deutsch connector. I am trying to find a resolve in the difference of the two wiring set ups without having an real instructions to go off for what would require me to do to make this set up work while still being able to delete the power transistor unit while also retaining the tach signal. I am using ecmlink v3 for tuning software so my set up will still use wasted spark.
I have also looked into ohm racings set up for coil on plug but I would rather not spend another $1k on the car to acheive the same goal that the antilad racing setup can do for half the price.
Car has all other supporting mods and am currently in the process of changing from holset hx35 turbo to xona rotor xrc6464s turbo with artec stainless cast manifold as well as FIC 2150 high z injectors, single rewired walbro 450 pump tuning on flexfuel for e85. Looking to run 35-40 psi to touch the 700hp mark. This is a weekend warrior street car that will never see track time. From what I know the antilag setup should be able to accomdate me in my goals without having to break my bank on the ohm racing set up.
I have searched the forums and studied and read the basic denso coil on plug diy walk through but really I am looking for other users experiences and input on the antilag racing set up without having access to their installation instructions. I have reached out the antilag racing to see if I can get their instructions without purchasing their setup but I have yet to hear back from them.
Any help, input, experience, and advice would be greatly appreciated.
People put a single dtp connector for ease of use. You will be using the wires from your transistor plug only so it makes sense to only have 1 plug. If you are using ecmlink and have to swap your plug wires to get the firing order correct you are going to be swapping the the blue and brown wires to get the correct firing order.
I appreciate that information and you getting back to me. In the photos of the antilag set up for sale, thr wiring colors don't match that at all. There is a green, blue, and yellow wire visible in the photo which leads to some confusion for the wiring part on my end.
Thank you very much for your time and input. Do you have any recommendation toward a coil on plug set up for a 2g dsm other than the antilag racing kit?
  • For sale 4G63 Frontline Fabrication V2 Billet Valve Cover
    Frontline Fabrication V2 Billet Valve Cover $750 + shipping & paypal fees* swivel AN fittings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
