Clutch replacement question
Cruz67
72
Dec 17, 2010
Albuquerque, New Mexico
Is it ok to replace the disk if there is nothing wrong with the pressure plate? Also where could I find just the disk if so? Thank you in advance
Yes any parts store, but since your there i would change it in case problems arise shortly after you get the clutch disc in, and change the tob, get a oem one. Do it once and right, i hate doing things twice
its a bit of work so i would change everything.
Money is just kind of short right now thought I might be able to save a couple dollars. I already have the tob thanks for the quick reply. Autozone and oreilly don't sell just the disk though.
How do you know the PP is fine? What's the clutch doing that it needs replaced?
Do it right or do it twice. If your not planning on a million hp you can just settle for the stocker. It is recommended that you resurface your flywheel. I've personally did two clutch disc install and no flywheel, just a resurface. Everything is fine.
