Clutch pedal stuck
GrnMnstr
Nov 22, 2012
oshawa, ON, Canada
I just bought the car 4 days ago been driving fine but when i pulled up to the light i pressed the clutch in and it wouldnt come back out
Its dark out and i dont have a garage to work on it but i got all of tomorow to check it out
i am a big newb but im assuming its either the master or slave cylinder. what is the easiest way to check this
i dont think bleeding will help because it was driving fine and i hadnt changed anything
any help wold be greatly appreciated
I tried bleeding and the slave is leaking ordered a new one itll be in monday hopefully thats all it is
One thing to check also when I replaced my master and slave: the line needed to be reflared and was still leaking. After the install make sure there isn't any fluid coming from where any of the lines connect. It took me a day before I got stuck again and looked down and saw it.
ill add to saying its the slave cylinder. Its leaking of course by the 5th pump of the clutch pedal its not going to work. LOL
it was the slave bought OEM with a speed bleeder made install super easy.
the old slave cylider was not only leaking it was broken the tip actually broke off, what would cause this?
