Clutch Line?
Swish
125
Sep 14, 2009
Savannah, Georgia
Ok so i have searched everywhere including Rock Auto to find the OEM clutch ine that runs to the Slave Cylinder ,
Just in case i sound stupid and it isn't called a clutch line, im talking about that FORMED metal line that runs to the slave cyl.
Mine is just rusted to crap and i need another one or is there an after market line to replace it? I know i have seen SS lines but im not sure if they are from the Master to that or the master all the way to the slave..
any help is appreciated! for mine is leaking like crazy because i cant tighten up the little nut thats on it
Why would you want to use the OEM line...
I still use the stock hard line with the short SS line attached. The hard line won't give you the spongy feeling the rubber lines will so generally it's fine to use. I'm assuming that's what you were asking?
But as for a replacement, I'll agree with you Mike.
No problem Swish. Google is your friend :thumb:
