Clutch Line
97MitsuEclipse
55
Mar 27, 2006
Ridgefield, Washington
So my clutch line split (the flexable part) and I got a ss replacement for it, but I can't get the orginal line off (its a 95 GSX). For the fender fitting, does the 10mm nut unscrew or does the fitting unscrew? Or are there any tricks to get it off? Thanks :dsm:
with the clutch lines you have to be careful not the strip the head of the bolt. the best way to get a good grip is a 10mm flarenut wrench. once the nut gets unscrewed it should slide up the hard line. then removed your cracked hose and replace it with the new one. tighten it up. bleed the system and you should be good to go.
