Check out how my timing marks line out
jc_is_the_man
40
Jul 17, 2008
New hyde Park, New York
Hmmmm, is this normal??:rolleyes:
You should have rotated the motor so that the dowel pins on the cam gears were at the 12 o'clock position BEFORE removing the timing belt. It's hard to tell how things are positioned from that picture. Maybe another picture showing both cam gears a bit clearer. How do the marks on the crank, oil pump, front b-shaft look?
Agreed, you have sorta fubarred yourself. If I were you I would pull the cam caps/ cams rotate the crank to TDC and then reinstall the cams with the dowels at 12 o'clock to avoid bending anything up.
you will have another timing mark directly opposite the right cam gear mark, so when they both rotate around it will look more like they line up.
From the picture, the timing belt is still on.
WTF You shouldn't need to remove the cam caps/cams at all.
Check out this post on how to check your timing:
http://www.dsmtuners.com/forums/pro...engine-has-never-run-right.html#post151565942
If you can't get the timing marks lined up horizontally (then should also line up with the valve cover gasket if you look past the marks) with the dowel pins at 12 o'clock, then your timing is off and you'll have to reset everything. It does look off at this point though.
And if you want another opinion, take a horizontal shot of your cam gears with the marks lined up in the middle, the dowel pins at 12 o'clock, and include both of the cam gears completely in the picture.
Yup, your right my fault. Didn't think that one through before I typed. Wow and I really missed the timing belt that in the picture. Excuse my stupidity.
Damn, you're absolutely right.:coy:
It's ok, I forgive you both. We're all entitled to have these moments (I've had my own too!).
romeen said:
See Brian, this is just one thing that you have to look forward to as you get older....failing eyesight.:p
Haha, my vision is horrible already (and has been since I was in the 3rd grade) :cry: I just get to pay for contacts to fix it.
Yea, and if you accidently take the belt off before doing everything at TDC, turn the crank to 90* from TDC so the pistons are in the middle of their bores so they won't meet any valves when you turn the cams to their TDC position.
