changing engine harness
jbeaton9292
847
75
Aug 29, 2013
Sterling heights, Michigan
ok so im gonna be changing my engine harness out tomorrow and i have the dash mostly pulled from the car. its pulled out enough so i can get to the ac parts under the dash. there is so much stuff going on under there im not sure where to begin. I already took 3 12mm nuts off from the part to the right closest to the passanger door, what else do i have to remove i cant get the part out.
if someone has pictures that would be awsome as this is first time ive had the dash out of one of these cars, its intimidating to say the least.
for anyone else looking to do this once the dash was out there was 2 nuts at the bottom of the ac stuff and there was 3 nuts and 2 bolts on top. i unplugged all the plugs right there and i was able to tweak the big box far enough to squeeze the one all the way to the right out. after that just unplugged everything from the engine bay and pulled it on through pretty easy job install hopefully goes well!
