91+ engine harness
jbeaton9292
847
75
Aug 29, 2013
Sterling heights, Michigan
So i changed my engine harness to a 91+ harness i have 2 plugs with no home they are square 4 pin connectors just past where the starter harness plugs into the main harness what are they
My car wont even crank
Ok i was wrong 1 plug is a 4 pin and is a cruise control vacume pump plug? And the other is the one i linked to but i dont know where it plugs in
http://www.dsmtuners.com/forums/152709633-post7.html
The 6-pin plug you've linked to goes to this: http://members.shaw.ca/dsm.1000q/Engineprimer/1G/solenoids.htm.
*Credits to EZSpeed, photo found at http://www.dsmtuners.com/forums/blogs/ezspeed/3068-lives.html.
Neither of these, the cruise control plug nor the solenoid pack plug, will keep your car from cranking.
That thing is no longer in my car but ok any idea where to begin everything else is plugged in the car was cranking before i changed this
Check that you are getting voltage to the starter. If not, figure out why. That's 12v on the large black w/ red wire and a switched 12v when the key is in the START position for the black with yellow wire.
I see you got that thing changed out man I was sure the problem lied in the harness wiring it was a mess.
Yeah i dont know what it is ###### overlooking it im sure i put quite a few hours in today working on it so kinda exhausted
Have you checked the wiring for the clutch pedal switch or neutral safety switch if its an auto? Also have you check all of the major fuses to make sure you don't have a blown one?
