2G Catch can setup
DiamonDSM98
Supporting Member
27
4
Oct 2, 2017
Detroit, Michigan
I’m having crank case issues and I’m trying to solve it!
I have -10an fittings coming off my valve cover
-10an fittings coming off the oil cap as well and only 3 fittings welded to my can.
My question is should I add a Y adapter for my valve cover lines or add a Y adapter for my oil cap?
The spot where I have the filter on the catch can is actually a threaded fitting as well (-16an) that goes out to my exhaust. Which I plan on switching up
Please let me know what’s the best way to route this, I can modify it however.
Also is this over kill? Should I just add the two valve cover lines and maybe a line coming from the balance shaft inspection hole?
I feel like you have other issues going on if you’re still building pressure with a -10an and two -8an. That is far more than stock and should t be an issue even with higher boost. I run one -12AN line as my breather and stock pvc setup at 38psi without blowing out the dipstick.
8AN is sufficient. Mine is having lots of crankcase issues when I turned it up to 30psi (with two -10ANs) but I plan to rebuild it this winter so it's getting sent in the meanwhile. My old Galant VR4 had two -8AN from the valve cover and it saw 50psi a few times with no crankcase issues whatsoever. So, plan on reringing it or doing something in the near future. How big is the outlet to that can?
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
