catch can mounting spot 420a turbo
scottyhops
227
3
Jun 14, 2011
sussex, New Jersey
so i was trying to find a spot to put my catch can in and decided to make a bracket out of aluminum. it was about 3/4 wide, say an 1/8 thick. I put it in the vise grabed the propane torch to heat it up and went away bending it about 82 degrees. when i was going to mount it i had a allen bolt and i drilled it so it say into the bracket but turns out the bolt was to short so there went that idea and just used a longer bolt. polished the bracket up and installed. i have it so you can't really see it everything works how it should so I'm happy with how it turned out
on to the pics-
solid shifted bushings also in
overall how it looks
any thing i should do/concerns fell free to put your input. i want it to be prefect and I'm new to this catch can thing
