Catch can
akdov823
255
31
Sep 20, 2014
feeding hills, Massachusetts
I know this has been discussed a million times, but I figured I would throw my simple catch can up for guys that don't need a complicated setup. Also not much custom fab but sometimes simple is just as good.
Why such a large hose? That looks like it's in the way. Where does the other end run to? I can't see it in the photo.
Also those silicone rad hoses are no good.
Large hose because I didn't want to run two smaller breathers like most people, it's connected near the factory breather location to a catch can. Its a -12, not really in the way. The radiator hose has been fine for awhile now.
I'm also running -12 but 2 ports instead of 1 right off the VC like you have it going straight to a vented catch can but I can't tell did you drill out that hole bigger? If not, having such a large hose would be pretty useless.
. Ya I drilled a 3/4 hole and tapped it with a 1/2 inch npt
