Kdouglas89
- 436
- 11
- Jul 8, 2013
Davenport,
Iowa
I have done timing on my old 2g several times, and never had an issue. I replaced the timing belt on my recent 1g. I took the tensioner off, depressed it, inserted pin, and bolted onto block. I am turning tensioner pulley clockwise, but there is never a point when the tensioner wants to free up the pin. No matter how far clockwise I turn, it's still tight. Any help?
a new tensioner is always a good idea anyway but I agree. I just use the one that comes with the OEM tensioner.
. Pin should come out with proper tension on tensioner pulley... If you read the post, you would have realized I was doing everything correct. The tensioner was bad. Go be a dickbag elsewear.
