cams with balance shaft still in
steve3s
43
Feb 5, 2011
midland, Michigan
will haveing the balance shaft still on< will it make cam install any more difficult or is it stil pretty straight forward? I'm new to dsm's
Read the rules before you post on this site.
Grammar is pretty much mandatory. Think of it this way, you want us to answer questions for you ASAP. Well, it's kinda hard to read when you post a bunch of words with spelling messed up and punctuation is all over the place.. At least try; doesn't need to be perfect.
Plus I'm pretty sure Firefox has a spell check feature..
Anyway, your balance shafts are in block of motor, your cams are in the head.. Your balance shafts run off timing belt "B". The balance shafts don't interfere with you installing cams.. A buddy of mine on this site put in a set of HKS 272s and never touched the block.
Good luck.
Anyway, your balance shafts are in block of motor, your cams are in the head.. Your balance shafts run off timing belt "B" while timing belt "A" goes from oil pump, Cams, Crank. The balance shafts don't interfere with you installing cams.. A buddy of mine on this site put in a set of HKS 272s and never touched the block.
Good luck.
Lawls.
For one, my spelling is fine I just hit the wrong button and was typing fast. Also I just wanted my question answered I dont need the bs. Thanks for the answer though.
He's tryin to save you some hassle from the mods. Be respectful he's trying to help.
It's cool I mean no disrespect. I came here to get advice, not to start arguements.
The only way the balance shafts would effect a cam install on a 4G63 would be replacing the belts along with the timing belt while you have it apart and will need to re-time anyways. Other than that, they won't change anything. I think I know where you're coming from though, if I remember correctly the 6g72 has balance shafts in the head.
