rear balance shaft (with photos)
sphinx0nine
99
Nov 13, 2003
Calgary,
Hey guys,
I had to replace my oil pump, so after taking everything apart, i got to the rear balance shaft.
We pulled it out and found this, and a piece of metal at the bottom of the oil pan.
Smaller end of the balance shaft. This is the part that goes into the actual casing of the pump.
Middle part of the shaft, the brightest part is where its supposed to catch on the bearing.
Now i belive that the piece of metal was the bearing, and that the shaft has been turning at some random angle and thas what made my pump go bad.
The inside of the pump has major wear where the smaller propeller sits. i will post pictures of the block and the case sometime.
I wanted to know what you guys thought i should do.
Im looking at balace shaft eliminator kits.
Any other suggestions?
Thanks
yea i would just buy Balance Shaft eliminate kit there only like 43 bucks i have mine done great investment.
it was a stock system, and i was rebuidling it with a 60 trim turbo set up and supporting mods. I used the broken oil pump as a reason to make a much better set up.I am replacing my oil pump and front case right now and found that.
I will be installing my shaft eliminator kit during the next two days. And then finally putting all the stuff together.
I CANT WAIT!
