burnt valve, is head ok to rebuild
It appears that a machine shop could re-seat them. unless you have a way to seat the new valves. if you get a bigger bore valve then they will have to be re-seated and youll probably see little gains HP wise from extra flow.
yea that head is fine as long as the seats arent hurt them they can just be cut and new valves lapped in.
should be a simple fix, a valve job and surface and you should be just fine
you need to find out why the valve burnt in the first place,
a few things to read so you have some info....
I would have the nead pressure tested to start...
http://www.dsmtuners.com/forums/cyl...how-aluminum-head-pressure-tested-cracks.html
then be checked for flat
http://www.dsmtuners.com/forums/articles-engine-fuel/341627-how-check-head-warp.html
the head should also be measured for thickness, new thickness is 5.200 with a min thickness of 5.185 if you are thinner than 5.185 you will want to get a thicker head gasket
if the head is warped or has fire rings, and needs surfaced, DO NOT let the machine shop belt surface your head
http://www.dsmtuners.com/forums/cyl...0613-why-not-let-your-head-belt-surfaced.html
weather you run a composite headgasket or a MLS the surface finish should be about like this...
http://www.dsmtuners.com/forums/new...face-4g63t-cylinder-head-mls-head-gasket.html
then the seats will be cut (you may or may not need a new seat installed in the burnt valve hole)
http://www.dsmtuners.com/forums/newbie-forum/341297-how-replace-seats-aluminum-head.html
also you will want to have the springs tested, good chance they are wore out...
http://www.dsmtuners.com/forums/newbie-forum/341287-how-test-valve-springs.html
and some valve spring info...
http://www.dsmtuners.com/forums/newbie-forum/341209-4g63t-valve-spring-info.html
if you plan on running stock cams or a mid lift cam, the BC1100 springs are a good drop in spring and will work with the factory retainers on the 4G63
now you may want to have your valves back cut...
http://www.dsmtuners.com/forums/newbie-forum/341288-why-have-your-valves-back-cut.html
and you may want to do this oil mod
http://www.dsmtuners.com/forums/newbie-forum/341028-4g63t-head-oil-port-mod.html
best of luck with your head rebuild!
Thanks guys. This head came off a car I used to own 4 years ago. I'm not sure what caused it or even know how to find out. I bought it like this, just swapped on a different head on to fix it. Should I have the machine shop take it apaprt or can I go ahead and do that? I'm wanting to get a better head gasket and head studs and since I had this head laying around I figured I could rebuild it and put some cams in while I'm at it. Any recommendations on a head gasket and studs. I wanting 500hp. mods in profile.
Thanks again.
