YupinmyGst
- 0
- Sep 26, 2009
Strongsville,
Ohio
I just got my car running again after an AWD swap. The exhaust is filled with oil and it's smoking under boost. I have an HX35, it has no shaft play in and out or side to side. There is no oil in the intercooler piping or on the screen/air filter. There is oil between the exhaust manifold and turbo. made a new return line, put a new head on it with good valves. The compression is good. Plugs keep getting fouled. Unfortunately I don't have a wideband
but it was dynoed before. It has always smoked a little, but it use to be black smoke, now it's white. Could the turbo still be blown? Or could the rings be bad? needs to be retuned?
Please suggest additional tests.
Thanks
but it was dynoed before. It has always smoked a little, but it use to be black smoke, now it's white. Could the turbo still be blown? Or could the rings be bad? needs to be retuned?Please suggest additional tests.
Thanks
