BSE Kit, Parts Dino or Xtreme PSI?
DONT get the first one notice the lack of oiling groove on the stub shaft?!
Then look at the one from extreme psi....see the oiling groove. Looks like the extreme psi kit uses OEM parts. Dont take a chance use an OEM stub shaft as many ppl that didnt have had issues.
Balance Shaft Eliminator Kit Install
And a good read here
I say ExtremePsi! :thumb: I get all my perfomance parts from them. Fast shipping and are willing to speak to you over the phone for parts questions.
If I replace the timing belt and do the balance shaft kit what gaskets do I need to buy while I have things apart?
I'm also going to pull the cams so I can install the better lifters at the same time. I have a new valve cover gasket with plug well gaskets and a new water pump with the gasket for that.
Oil pump (front cover) gasket. I would put in both seals too (oil pump and crank).
