BSE kit
Alex Bland
666
3
Jul 2, 2008
Seabeck, Washington
ok i was looking at this guide
Balance Shaft Eliminator Kit Install
and people said to get these parts
MD103722 - Front Balance shaft bearing - $9.84
MD040597 - Rear Balance shaft bearing - $11.59
MD092785 - Balance shaft cap - $7.73
MD098626 - Balance shaft stub - $9.59
MD128107 - Balance shaft spacer - $3.84
but the guide does not say what to do with the balance shaft spacer??
I reused the sprocket with no problems. The spacer is just a waste of money, you won't see it once the cover is on anyways. You don't have to buy new bearings if you're careful either, just take out the shaft, turn it around, put it against the bearing and (once it's flat against the edge of the bearing) give a few slight taps to pop out the old one, turn it a little so the oil hole doesn't line up and tap it back in.
