93 talon tsi awd
- 43
- 15
- Jul 21, 2023
Olympia,
Washington
Well this is not a question i wanted to ask but here's some back story. I had to pull the trans to have a crack on the bellhousing welded and when i took it out i found another place where the trans case bolts together is broke off and im not sure if i should just replace the trans completly or try to get it welded and tapped, the damage in the photos was from the previous owner when they did the clutch. Any advice or ideas help
