Turbine Housing broken bolt
whitegst97
199
Sep 16, 2002
Miami, Florida
While taking of the 02 housing the rear bolt, the one between the block and the housing broke inside the turbine housing. I was wondering if when i put it back together with only three bolts i will have an exhaust leak? If so how exactly can i disattach the turbine housing from the turbo, i don't wanna take the whole turbo off. I know this garret is not the same as the 14b or 16g's it has some bolts, should i simply unbolt them? Any advice or technique will be helpfull. Thanks
Would it be cheaper to buy a 14B and the corresponding pipes, where can i find a t-25 turbine housing?
