Broken turbine housing bolt, How bad will it leak?
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
Hi, installing turbo and broke a turbo bolt,
3 still holding tight, will it leak?
is it ok to drive til my 02 housing gets here and i drop the turbo and extract bolt?
i drove mine with 3 in it for a long time and it never leaked.
btw: i need to see if you will pm me the mod on the shifter cable mod for the jdm tranny
Paxin with your luck the car will leak like bi*** and will drive you nuts man :p , just tighten the other ones down a little tighter and you should be okay. I have a tap for the turbine housing hole if you need to use one, just let me know. Later. :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
