miguelmcv
Supporting Member
- 2,718
- 261
- May 3, 2009
Fresno,
California
The valve that Miquel is talking about is the proportioning valve, not the check valve. Ignore him.
The check valve is the lump in the hose between the intake and the booster. When it's broken (or backwards), you'll have the symptoms described by the OP. Verify that air can flow from the booster to the intake, but not the other direction. If the valve passes this test, move on to checking the booster, itself, for leaks, as suggested by Bryan.
Sorry, My bad, I thought they were talking about the proportioning valve.
I can't tell anything else, which there are so many replies about where is the check valve and would be just repeating over and over.
Good luck, and hopefully is just your check valve that is leaking.
