Spoolin98
- 1,646
- 24
- Feb 1, 2004
Easton,
Pennsylvania
Hey guys I need some help with a boost leak. I did a leak test and im losing air from a hole in a nut on my boost controller. I dont think this should be this way, any advice or comments on why this is or what i should do? Should i just JBweld the hole shut? Heres a link to the picture of the hole that the air is leaking from, its a fairly large leak that will not allow the car to hold pressure. Thanks in advance.
http://www.allaboutimports.com/boostcontroller.html
The final goal is 20psi on the real bost gauge and allow no less than 30 seconds before it bleeds down to zero. Here are some tips for you on leak testing besides disconnecting the mbc.
