Blower Motor Resistor Location
mmountain
Dec 14, 2012
Fayette, Missouri
Alright, I am about 95% sure that my blower motor resistor is out. The only problem is,,,,I can't find it. It's a little embarrassing but can anyone help me out?
I found the blower motor relay there, is the resistor there as well? do I need to remove anything to get the resistor?
To see it you need to pull off the glove compartment and then look up and some-what behind the radio. It's kind of hard to get to, but honestly it's probably the easiest way to get it done. If I remember right there is carpeting you have to remove as well.
To save you time, if it isn't just one of the settings not working or maybe a few settings not working then it's most likely not it.
I've got the resistor! thank you, Its only low and medium that's not blowing, High more than works.
