420A Blower motor help
4g63turbo84
614
Dec 10, 2008
ocala, Florida
i cant get this dang thing out i got all the bolts out but this one that is almost on the fire wall and i don't have anything small enogh to get it out can anyone help me and tell me how to do it!!!!!!!!!!:confused::cry:
A little more detailed post would help along with some better grammar and use of the shift key. Where exactly is the bolt in question? Pics would help a lot.
I had the same problem. I think I used a wrench and pulled the blower unit out slightly (other bolts already removed) at the same time as unscrewing that bolt so the blower could shift away from firewall slightly. Also remove floor pad if you can.
If you bought the aftermarket that slips in, be careful you don't crack the case getting the old one out like I did.
