Spyder Blower Motor problem
95talongirl
Supporting Member
1,876
177
Feb 9, 2008
On a Jet Plane, Illinois
Hey... I'm having an odd problem with this 99 Spyder 2.4.
The car is having power draw issues. Figure out it was the blower circuit. When the relay is pulled, the car will start fine after sitting for an extended peroid of time. I have noticed that it is getting constant power. You can turn the blower on without the key in the ignition. What could cause this? I replaced the relay for s and g's and still doing the same thing. It will also blow fuses from time to time.
Could the motor itself be shorted? I also did not see any cut up wires under the dash. Thanks!
Which fuses is it blowing? There are two..
No. 11 (30 amp) "Blower motor" or
No. 13 (10 amp) "Blower motor relay"
This would help greatly in narrowing down the wires and also if it's an AUTO or MAN. The wiring systems differ from each other. Not much, but why take the chance?
