1G Bigger intake, exhaust stock ecu?
Adrian97
5+ Year Contributor
100
Mar 3, 2018
Göteborg, Europe
Hello!
Can i change stock IC and Piping to VRSF and exhaust to 2.5-3" without any ecu change, I mean do I need any ecu tunning or remapping?
Riding on stock ecu with bigger IC and piping and Exhaust does not affect the engine badly or something like that? (Idle bouncing, run rich or lean e.t.c.)
Generally yes, since it is a maf car. Long as you don't screw with the maf/inlet pipe. However, a side effect of the mods you suggest I'd increased airflow/boost creep. This might put you into fuel cut. Also make sure you have a boost gauge to check, and a upgraded fuel pump along with a fresh filter.
