1G Best way to clean up Tstat housing?
Mahreeoh17
5+ Year Contributor
272
267
Jul 12, 2020
California
Purchased a 1G thermostat housing for my upcoming swap and it looks kinda beat. I'm wanting to clean it off a bit and probably spray it with some VHT silver to match the heads. I have a glass bead blaster at work, is this sufficient to clean it up a bit or will it get damaged? Not sure if it's aluminum or if that matters.
Dont know why this posted in the newbie forum but mods please move if necessary.
Thank you guys. Same go for the throttle body? I'd like to clean the housing on that too.
After you glass beads you may not want to paint it as it will look new. Up to you. The only process I've seen that is even better is vapor blasting. I've had several aluminum items glass beaded and they look great. Small parts I've now purchased a vibratory tumbler but I'm just now getting started.
I ended up spraying them with a Rust-Oleum enamel primer and metallic silver and they came out looking great. I wanted to paint just so it'd stop any future corrosion.
Ultrasonic cleaners do a very nice job on aluminum and many other parts, one of the best investments I've made in my garage.
This is after only 20 minutes. For really bad stuff sometimes you need to brush the heavy grime and run a second cycle but it does a great job overall.
Nice for small stuff,, big stuff I want to glass bead ill be doing small stuff, over the winter.
I bought a media blasting cabinet for this project on my car. I also had to buy a 60 gal air compressor to run it bc my 20 gal was nowhere big enough. I have been glass beading a lot of stuff.
I was wondering what to do about mine as well. I will probably glass bead it if that is safe.
Vapor hone for sure, i found a local guy who does it and you can't tell the difference between new and used
Somebody did a better job with your coolant than most I see. All the connections are usually corroded/pitted. Yours look new.
If I had a cabinet and a 60gal tank on a gas run compressor, I would find whatever I could around the house to blast..
Mine runs on 220v.
That looks awesome!
