Resolved Banjo bolt length? For Fp 3052/inline filter
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
So can anybody tell me what the correct length or part number banjo bolt I need to feed the fp inline filter to head? The standard 10mm.1.25 I ordered from extremepsi was too long and it doesn't give me a length to choose from. Hardware stores here in town don't seem to carry banjo bolts
I don't see the crush washers, are you using them with the banjo bolt? There should be one on each side of the banjo fitting.
Just curious if you ended up locating the correct banjo bolt for your filter restrictor? I lucked out having one laying around that was perfect fit. I did sorce the inverted flare fitting at the turbo from FP.
