Balance Shaft Tensioner pulley DELETE!(BSE KIT)
Coder24
346
Jan 16, 2006
Marysville, Ohio
Ok I have read the BSE kit and all the junk with it. but I cannot find a bolt short enough to sit flush with the oil pump for where the BS tensioner pulley goes... Is that ok as long as I use RTV? Or can I Grab some washers and throw them on there...and RTV the threads?
Look mang, use the screw that holds the front balance shaft sprocket onto the front balance shaft.
Use the screw and washer with rtv and you're golden....
I've done 6 and counting.
Man, how did you miss that...
It's even written in red text.
http://www.vfaq.com/mods/balance-shafts.html
3rd picture after the parts list, then look to the right in red text.
Well I got something to work but heres whats vfaq says...
"When reinstalling the oilpump cover, make sure to either get a new shorter bolt, or install the old pulley and bolt." It says to Reinstall either the old pully and bolt or get a new shorter bolt nothing about being able to take it from somewhere else...Thats how I missed that...But thank for the help.
