4GJS Balance shaft delete
Windstarpro
Feb 6, 2011
Gloucester, Virginia
I was told that this site is the best by a member. I actually have a 2001 Sonata with a G4JS 2.4 DOHC and Im afraid of leaving the balance shafts in. I already have the engine out and will be doing work to the head, so pulling the balance shafts is no big deal. Anyone know the part numbers, or where I can get the deletes? Ive seen them for the Evo where you install a NON-accentric shaft in place of the offset, or accentric balance shaft. Everything Ive read about the other mitsu's is that this is the best way to go since the oil pump is supported, and everything runs true.
