randizzle420
- 256
- 25
- Sep 20, 2009
El Centro,
California
Um not sure whats up with this shit yellow wire but it just runs straight down onto the middle of the floor at the back seat, then travels further on the ground between the passenger seat and center console and weasles it's way down into the radio area then goes deep into where all the wiring plugs are at if you removed the radio and goes towards the engine into the abyss. Idk I'm guessing it's to power the fuel pump but is it supposed to run like that are down by where the passenger door is along with the speaker wire?
Now I have this boost controller for one I do not want the damn thing mounted where a radio should be especially sideways. I have zero idea if the thing is even hooked up. I'm doubtful as the guy couldn't finish anything he did on the car. Also the white and black plugs that aren't connected to anything is that for the radio? I want to put a radio in the car but as far as I see these are the only two things I see that can connect to anything besides the wiring with the speakers for the rear large speakers and front door speakers which have an end on the input side of the wires that look like headjacks. Not sure if that is gonna work with an aftermarket radio.
Now this. I don't think theyre hooked up correctly or at all I'm assuming. I do like the three gauges on the A pillar but of course he just didn't finish something he was working on. I'm not sure what would be a good idea. Figure out how to hook up the gauges and add another one to the blank spot (not sure what kind of gauge to use either)
