2G Help With Wiring Blackbox ECU into Spyder GS Swap?
pointblank9957
284
10
Jul 12, 2012
Sheboygan, Wisconsin
Doing an ECU swap in my 98 Spyder GS. The ECU that's going in it is out of a 99 GSX (flashable).
Ceddy said there were some differences with the ECU's concerning the Fuel Pump Relay (Spyder using 5v and HT using 12v). I could use a Fuel Pump Rewire for this right? Run Pin #8 wire back to the relay and bypass the grey module?
It's Auto if that makes any difference
From what i can tell, looking at both pinouts, the only difference b/t the Spyder and GST is that the Spyder is missing:
pin 3: Fuel Pressure Solenoid
pin 7: Engine/Transaxle General Control Torque Reduction Request Signal 1
pin 8: Fuel Pump Relay (not missing but different voltage)
pin 43: Engine/Transaxle General Control Torque Reduction Request Signal 2
pin 46: Engine/Transaxle General Control Torque Execution Signal
pin 58: Tach Signal Output (Engine Ignition Signal on GST)
pin 61: Fuel Tank Pressure Sensor (Spyder has this and GST does not...)
pin 78: Knock Sensor (+)
pin 91: Park/Neutral Switch (originally Chassis Ground)
-I don't think the FP Solenoid needs to be there right?
-What the **** is Engine/Transaxle General Control Torque Reduction Request Signal and does it need to be there or will it throw CEL's or worse not even run/shift right?
-What do i do with Engine/Transaxle General Control Torque Execution Signal?
-Pin 91 doesn't need to be grounded anymore correct? just to the P/N Switch?
-can i just eliminate pin #61 Fuel Tank Pressure Sensor?
any help would be GREATLY appreciated!
