ECUflash Anyone local to Portland-Salem areas
Sjd6795
614
121
May 14, 2014
Wilsonville, Oregon
Looking to see if anyone is local to portland or salem areas I am kind of in between. That has experience with ecuflash, I have adjusted some things and car runs a little better but doesnt seem to matter what else I adjust. To get the car leaner. WOT is ok at 10.5 but idle and cruising is rich. I've adjusted scaling and latency and increasing latency only made it worse.
So comparing my current fuel maps to the default 2g eclipse rom in ceddymods. I notice they are drastically different, I don't know what I am looking at but it seems the ceddymods is a bit smoother?
Also bottom right corner of photo how come there is no option to change that vehicle info or does it even matter? My car is a 97 gsx with the 98 black box ecu.
English is closed due to Covid. They have been since mid March. I have been waiting to do engine management for that reason. hopefully RIX or someone else can help you with your problem if you need an immediate fix
