ECUflash ECUFlash Openport 2.0 help
I can’t get the 1998 gsx into the vehicle selection but I got it into the open rom documents what am I doing wrong
Or did I do it correctly and just have to plug it in now
I have purchased an open port 2.0 and I’m going to install the 2.5mm flash connector to pin 79 but I cut the cable provided and it only has 1 inside it do I need to get my own 2.5mm to separate ground or am I just dumb and hook it up
I have figured it out if you have a Mitsubishi adapter from Tactrix you cut off the plug and it only provides continuity to the tip as it should for flashing when connecting to pin 79 in black box ecu I’m will be taking the egr pin out of the ecu and connecting it to the 2.5mm moon jack as egr is deleted when a 2 g has a 1g throttle body
