ECUflash Openport 2.0 help
Kng Nothg
79
Dec 1, 2002
Lynchburg, Virginia
Hey fellow DSMers! I can't seem to get the Tactrix cable to pull the information from the ECU. I have pulled the ECU and checked to see if the code is correct on the board. It is the flashible ECU. I'm running windows 7 thanks:banghead:
Just save the Rom like you have...
Then Just flash the Correct Modded Rom with the Matching Xml you want for your ECU should be fine you already saved the the image to flash back to stock if wanted.
You don't need to mod the stock Rom so it doesn't matter and the Roms are interchangeable between all the Ecus with the same PCB Code as there is just One Rom structure with Ceddy Mods. No messign with the correct rom/definition like various Evo ecu's... . Just make sure your using the newest versions of the files your flashing and you will be good :)
